3pt lift don't lift
   / 3pt lift don't lift #1
Lickity Split
Germantown WIsconsin
MF65, Toro Groundsmaster 72
I have a old MF 65 and the 3pt lift don't work.
it will work for 10 min and then lower down.
I changed the oil it was milky.
It still dose it with new oil in it.
The only way I can get to raise up is to turn off the tractor and let it sit for 5 min start it back up, and it will work for 10 min.
Thanks Lickity Split
   / 3pt lift don't lift #2
Plugged pick-up screen? Fluid level too low? "Milk" = Water! ~"Scotty"
   / 3pt lift don't lift #3
yep.. milky means water or air.. if wter.. then could also mena rust.. and there is always the possibility of grit nd gunk.. none of that is good for control valves.
soundguy
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
