3pt king kutter brush hog
   / 3pt king kutter brush hog #1
nwngunner
Maquoketa, Iowa
806Farmall 1650Oliver
I have a 3pt brush hog that i was thinking about converting to work on my skid steer. I dont know how well the mower would work going backwards? I know i can open up the tail to allow me to cut wider. I also know i would have to change the pto 90 degree gear box over to something for hydro. I can get a ssqa plate that has the 3pt connections on it.
It was just something that i was kicking around in my head. My 3pt went out on my tractor and havnt had the time or the want to rip the rear end apart to fix it. Being i very rarely had a need for one. Figured i could save my self alot of money being i already have a rough cut mower.
   / 3pt king kutter brush hog #2
I've long thought about the same thing and would love to have you try it so I could see how it works!
You'd need a 3-point adapter like this:
Skid Steer Attachments Pallet Forks Hay Spears Bobcat Cat John Deere Mount Plate
You'd need a motor like this one, rated at 35 HP at 600 RPM:
Surplus Center - 7.63 CU IN PTO DRIVE MOTOR
It already has a PTO splined shaft. Figure out a way to bolt the motor to the mount and run some hoses and you're done. Conceptually it's very easy. Very curious to see what details I'm missing.
i think i would have to rebuild the 3pt on the mower, mine is bent to **** and i dont know if a 35hp is going to be big enough. My cutter was rated for 60pto hp, it will take 3+ inch trees. I will have to do some looking in to it. Also i would have to cut the back under the deck to allow a larger opening. Put chains on the front to keep it from kicking stuff in to the skid steer
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
2020 Kubota B2401 (A50120)
2020 Kubota B2401...
2002 TCTC 6'x12' Trailer (A50121)
2002 TCTC 6'x12'...
