3pt implement dropping
   / 3pt implement dropping #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
What causes a 3pt hitch implement (box blade, disc, bush hog) slowly drop to the ground while traveling? Most of the time I have no problems but now and then, all of a sudden, I will realize that the box blade is on the ground. I checked the hydraulic fluid level and it is full. I thought it had something to do with traveling on rough terrain, but today I was carrying some items in the FEL up my drive way, and the box blade slowly lowered.
Thanks in advance
   / 3pt implement dropping #2
Not sure if the CK series has a knob under the seat, where your foot might hit it occasionally, that adjusts the lowering speed of the 3PH, (like there is on the DK series). If there is a knob I'd tighten it up slightly, and see if that retards the lowering of the 3PH, while moving with a load like the BB. Don't tighten it too much or the 3PH will end up not lowering....
   / 3pt implement dropping #3
Book says to snug it all the way up when traveling.
   / 3pt implement dropping #4
Do you have a rear remote? Did you accidently turn it on?
I have the rear tilt on hyrdaulic. I have at times pushed it too far one way or another and lose power to the 3pt, but that is pretty noticeable, and was not the case for the 3pt dropping.
I keep the knob turned for fastest up and down, so I will try to turn it the other way when traveling and see if that helps.
Thanks for all responses.
   / 3pt implement dropping #6
It sounds to me like yor ML valve may be leaking and causing it to drop wih the load on it, I would contact my deaer and have them check it out. May possible need to be cleaned or replaced.
New Long Forks (A53002)
New Long Forks...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
