3pt hydraulic lever became very difficult to move (how to fix) 4400HST
   / 3pt hydraulic lever became very difficult to move (how to fix) 4400HST #1
Mike_S
South of Kansas City
JD4400HST
The hydraulic lever beside the seat that controls the three point has become VERY difficult to move on my 4400HST -- any suggestions on what I can do to fix this issue -- this issue makes working with a rear blade very difficult...
Thanks,
Mike_S
   / 3pt hydraulic lever became very difficult to move (how to fix) 4400HST #2
Have you ever lubricated the linkage? There should be a few joints and a friction plate for the lever. Sorry, I can't post a pic from JDP at this time.
   / 3pt hydraulic lever became very difficult to move (how to fix) 4400HST #3
My 5105 did this a while back. It turned out the screw at the end of the controls had tightened down and was the cause of the bind. I had to take off the fender to get at it but was able to remove the screw and put some Locktite on it. I then tightened it down enough to hold everything together but loose enough for the control to move freely. Its been that way for a couple of years with no problems. Hope yours is as easy a fix as mine was.
   / 3pt hydraulic lever became very difficult to move (how to fix) 4400HST #4
Pull the suspension seat off and tithe plastic on both sides. That will let you get to the linkage. Should be obvious at that point.
   / 3pt hydraulic lever became very difficult to move (how to fix) 4400HST #5
From JDP, Fluid Film works great for the linkages, do the joystick as well:
Freightliner Tender Truck - Adams Tender (A53473)
Freightliner...
2022 ALLIANCE NORTH AMERICA, INC SDG45 GENERATOR (A53843)
2022 ALLIANCE...
2018 RoGator 1100C (A53473)
2018 RoGator 1100C...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
