3pt hitch rototiller
   / 3pt hitch rototiller #1
diggerman
canada
135MF ,265MF, 820 belarus
I was thinking of building one and wanted to know if anyone on here has built one.
   / 3pt hitch rototiller #2
I thought about building one after dad sold his yanmar tiller to the neighbor with another tractor and I bought the Yanmar. THe dealer doesnt have any nice tillers at the moment but they have alot of junk ones and stalks with good tines. I thought about buying a stalk and making a little car rear end my gear box but run a sprocket and chain down form each side. I came up with the ideal to make a tiller for the 4000 Ford at work a nice tiller. I can buy a goood Yanmar tiller when they are in for 250 though.
   / 3pt hitch rototiller #3
I helped my brother build one about 15 years ago from various spare parts. He had a Ford 1700 (~25 pto hp), and it was all it could do to run it. But, we didn't do much in the way of gearing experimentation. As I recall, it was a simple design with a 3 pt hitch connected to a piece of 8 or 10 inch channel oriented perpendicular to the line of tractor travel. Power was transferred by shafts from the PTO through a 1:1 90 degree gear box to one end of the tiller. The tiller was maybe 4 or 5 ft wide, so it was offset to one side to allow a slight overlap on the previous pass without the tires traveling over the previous pass. We just used standard garden tiller tines bolted to steel plates that were welded to a shaft that was the full width of the tiller. A chain was used to transfer power from the upper shaft to the lower. The tines worked fine, but wore at a rather rapid rate. Unfortunately, I don't have any photos. I could probably sketch something out if all this description doesn't make sense.
I was thinking of using a 3/4 ton rear end with one side driving the tiller and the other acting as the slip clutch. I 'am planning on buying heavy duty rototiller tines for it.I need it for the garden and some field work. I priced one for what I want and it was $6000 can so I thought I would try and build one. My dad run a small scrap yard 4 years ago so most of the things I need are there .The only thing I need is the tines and time.
378810 (A51572)
378810 (A51572)
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2018 INTERNATIONAL LT625 SLEEPER TRUCK (INOPERABLE) (A52472)
2018 INTERNATIONAL...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
