3pt hitch on 670 (650?)D
   / 3pt hitch on 670 (650?)D #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Trying to find out more about the 3pt. It doesn't have a FEL.
It's not my tractor so I don't want to sink a lot of $$ in it.
in
if you have a front end loader the tractor will need hydralic tranny fluid.if you just have the 3 point hitch you can use gear oil.the manual explains it.try links for a manual. Valley Power. Sheaffer's Town & Country Tractor . used compact tractors, front end loaders, backhoe attachments, implements
it's stated "you can use gear oil".
Can I also use hydraulic?
Any pointers to where drain valves, filters etc. are?
thanks
2008 JOHN DEERE 672D MOTOR GRADER (A52705)
2008 JOHN DEERE...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
