3pt hitch drops too fast? 2004/2425
/ 3pt hitch drops too fast? 2004/2425 #1
Garycw
Platinum Member
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
Just got a farm pro 2425 and still sorting things out. I've noticed the 3pt hitch that has a 500 lb bush hog attached tries to slam down when handle lowered. I can ease it down if I lightly ease handle. The hitch seems to go up extra high when lifted and throttle recede up. I've seen the knob under seat, but looks like it's down tight. Is there anything else to check or is this normal?
/ 3pt hitch drops too fast? 2004/2425 #2
The knob between your legs controls that drop speed, you need to look real close there is a set screw with a little flat screwdriver slot that you must loosen first, make sure the implement is on the ground and DO NOT TURN IT COMPLETELY CLOSED, or you will have to relieve the weight to get it to drop, just start closing it off a little at a time, when you get it where you want it, re-tighten the set screw
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Thanks tommy. Sounds simple now. I saw the small hole in knob but didn't know it was set screw. That explains why knob felt frozen in place
Ok thanks. Hope that helps. Kinda scary for it to slam down.
/ 3pt hitch drops too fast? 2004/2425 #6
On mine that setscrew dosn't lock the valve in place. It is in a recessed area in the shaft. I think it is there to keep you from unscrewing the knob too far and getting a hydraulic oil enema:)
Like he said, adjust it slowly/a little at a time. The pointed head at the other end of the shaft is pinned into a slot in the shaft so it can move up and down. The oil going to the 3PH comes up from the bottom and flows around the head, pushing the head up and out of the way so the lift will lift a heavy impliment at full speed. When you lower the 3PH the fluid flows back down alongside the head and pulls it to the more flow restrictive position to slow the fall of that heavy impliment. Too tight, and it will act like a checkvalve and stop the flow out of the 3PH. The 3PH will go up, but it won't go down. And once it is like this with a load on it, it hydraulic pressure from the weight of the impliment hanging on the hitch pushing down on that head locks that knob so you cannot unscrew it. Like Tommy said, It will stay there untill you get the weight off of the hitch. I have a bank on my property that I use when I am setting the valve for the brushhog, I go over and do it near the bank so I can unload the hitch if I screw the valve in/down too far:)
Thanks Ron for the advice & tip. I'm assuming that turning clockwise refuses the back flow, & lets the hitch drop slower. This bush hog is 400 lb. As well as a box blade that may be on it too. I'll try to find a happy medium so if o use a lighter implement like seeder, (125 lb) it will still go down.
/ 3pt hitch drops too fast? 2004/2425 #8
You are correct, clockwise screws the tip down into the body and makes the return flow more restrictive.
Does your tractor have a female quick connect fitting on the right side pointing to the rear? Some(like mine) do. If you have that fitting, the way you send pressure to it is to screw the speed reg in all the way till tight. The common belief is that the single fitting is for a dump trailer. With the speed reg closed, the 3PH control will raise and lower(pressure up-gravity down) a single acting cylinder attached to that fitting just like the 3PH...
I found the set screw. Wow it's small. I had a screwdriver thy fit , but started to strip head. I've got some gunsmith drivers I'll give a try after some PB blaster on it. It drops just about right with nothing on it.
/ 3pt hitch drops too fast? 2004/2425 #10
I have never adjusted my drop speed, it is set all the way open. I just am very careful when moving the lift lever and lower loads slowly that way.
Cleat
/ 3pt hitch drops too fast? 2004/2425 #11
Old thread, but I just had this same problem.
Gary - were you able to get that set screw out (or did it strip completely, like mine did)? Screw extractor didn't work on mine, so I think some water must have gotten in there at some point. I ended up drilling out the set screw and chasing the threads with a 5mm tap.
Ron - I think you're right about it not locking the handle/shaft in place like a normal set screw. When I removed the handle and shaft, it didn't look like the set screw had ever touched the shaft itself (no scoring or marks on the shaft at all).
Has anyone removed that set screw and replaced it with a small bolt? I was going to call Tommy and order a new set screw, but I'm thinking a bolt would be easier to remove if it gets rusted again. I think it's a standard bolt size: 5mm/0.8mm pitch. If I don't need to use it like a regular set screw, then I won't crank it down tight onto the shaft. My plan is to use a long bolt with a lock nut on it to set the right depth. Any better ideas?
Thanks,
Old thread, but I just had this same problem. Gary - were you able to get that set screw out (or did it strip completely, like mine did)? Screw extractor didn't work on mine, so I think some water must have gotten in there at some point. I ended up drilling out the set screw and chasing the threads with a 5mm tap. Ron - I think you're right about it not locking the handle/shaft in place like a normal set screw. When I removed the handle and shaft, it didn't look like the set screw had ever touched the shaft itself (no scoring or marks on the shaft at all). Has anyone removed that set screw and replaced it with a small bolt? I was going to call Tommy and order a new set screw, but I'm thinking a bolt would be easier to remove if it gets rusted again. I think it's a standard bolt size: 5mm/0.8mm pitch. If I don't need to use it like a regular set screw, then I won't crank it down tight onto the shaft. My plan is to use a long bolt with a lock nut on it to set the right depth. Any better ideas? Thanks,
No I didn't get screw to turn. I was just careful when lowering, being careful to ease lever down slowly.
/ 3pt hitch drops too fast? 2004/2425 #13
Thanks Gary. I do the same thing, especially since it's been really hard to adjust. But now that I've replaced the set screw, I'm hoping my adjustment knob will be a lot easier to turn.
/ 3pt hitch drops too fast? 2004/2425 #14
I wanted to report back on the results of replacing the set screw with a hex bolt. It's a lot easier to adjust the knob and I now have confidence that the hex bolt is in the perfect position -- because I can look down and see the distance from the bolt head to the knob housing. I added an extra nut to the hex bolt in order to make sure the bolt doesn't back out with vibration.
When the 3pt hitch is loaded, it's almost impossible to adjust the knob, but once the pressure is released, it's very easy to adjust.
Good deal. I just learned to live with mine controlling the drop with lever handle.
/ 3pt hitch drops too fast? 2004/2425 #16
Do you know the size of the bolt you used?
/ 3pt hitch drops too fast? 2004/2425 #17
The bolt size is M5 x 0.8mm pitch. At first I used a long bolt (20mm) with a stop nut threaded onto it, but it looked like it was sticking out too far.
I switched to a short bolt (13mm) and used a thin washer and a lock washer to get the depth setting just right. The collar of the adjustment knob shaft is only about 2mm thick, so it's important to get the end of the bolt to engage that collar solidly. But the bolt shouldn't be so tight that it keeps the knob from turning.
Clear as mud?
/ 3pt hitch drops too fast? 2004/2425 #18
clear enough to get one lol
2013 FORD F-350 (INOPERABLE) (A60736)
2013 FORD F-350...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2023 Case TV450B (A62177)
2023 Case TV450B...
500BBL WHEELED FRAC TANK (A60736)
500BBL WHEELED...
