3pt. hitch designations
   / 3pt. hitch designations #1
sleepyhollow
Connecticut
JD 4310, eHydro - R4, dual SVC, speedmatch/cruise, rear floods
Hi Folks,
Could someone explain the 3pt. hitch designations that you see batted around in tech specs and discussion threads? What is Category 0, 1, 2, 3, 4 etc?
Does it relate to the lift capacity or a class of implements that work with the hitch? Is there any connection between this and the rear PTO?
Thanks to whoever can clear up my confusion/ignorance.
-Jonathan
   / 3pt. hitch designations #2
Jonathon, this is a frequently asked question. I never heard of a category 4, but for the others, look at <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=buyjd&Number=23048&Search=true&Forum=All_Forums&Words=category%20three&Match=Entire%20Phrase&Searchpage=0&Limit=50&Old=allposts&Main=23026>this link</A>. It is not a lift capacity, but is related to the size of implement that can be used. Some larger tractors are equipped for both category I and II.
   / 3pt. hitch designations #3
Found this info at http://www.tractorsmart.com/enter.htm
Hitch Top link Lower link Lift Arm Vertical
Category Pin Diameter Pin Diameter Spread Height
0 5/8" 5/8" 20"
1 3/4" 7/8" 26" 18"
2 1" 1-1/8" 32" 24"
3 1-1/4" 1-7/16" 38"
Thanks to Bird and LGinIA for helping me out. -
Jonathan
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2014 JOHN DEERE 250D SERIES II OFF ROAD DUMP TRUCK (A51242)
2014 JOHN DEERE...
