Backhoe 3pt backhoe
   / 3pt backhoe #1
vtkubota
Northwestern, VT
B7500 Hst
Need some advice;there is an auction nearby that states there will be 3+ 3pt backhoes for sale new and used. Which peaks my interest. What should I look for as far as wear and tear and how about pricing, I realize that it is an auction. The add doesn't state name brands. I have a B7500 and don't want to get something that doesn't fit my tractor. Any advice would be appreciated! /forums/images/graemlins/wink.gif
   / 3pt backhoe #2
I have a B7500 with a subframe bradco BH and Kubota does not recommend using a 3pt BH, dealer said problems with breaking the case. I did not argue the point since the subframe looked to be alot more structually sound.
I am glad I have the subframe due to the stump digging/root breaking I do puts alot of strain on the tractor.
   / 3pt backhoe
Thanks I will keep that in mind. I'll send out a post if I purchase anything this weekend. Thanks again.
   / 3pt backhoe #4
<font color="blue"> I have a B7500 with a subframe bradco BH and Kubota does not recommend using a 3pt BH, </font>
While a subframe backhoe sure seems better than a 3PH backhoe, it should be poiinted out that the Kubota B4672 backhoe, which is the hoe Kubota puts on the B7500, is a 3PH backhoe...
So it is not correct to say Kubota does not recommend the 3PH backhoe on their tractors. The BL4690A on my B2910 is also a Kubota 3PH hoe on a Kubota tractor... /forums/images/graemlins/smile.gif
   / 3pt backhoe #5
I'll probably see you there in 'Georgia' which is near St. Albans? I am also curious about the backhoes.
Tall bearded mid 40's and male pattern baldness driving a muddy green overpowered noisy 99 cummins dodge ram.
See you saturday!!
   / 3pt backhoe #6
Well, did you find one?
I gave up by 2pm but saw that bradco needed a home...
Did you see what it went for?
Chariot 12' Inclosed Trailer (A50515)
Chariot 12'...
1988 CATERPILLAR 815B PADFOOT LANDFILL COMPACTOR (A51242)
1988 CATERPILLAR...
Year: 2008 Make: Chevrolet Model: Impala Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 (A51694)
Year: 2008 Make...
Swict 10' Fork Extensions (A50121)
Swict 10' Fork...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
