3pt and Front End Loader Out
/ 3pt and Front End Loader Out #1
ben9019
My FEL and 3pt hitch hydraulic stopped working recently. Cleaned filter. Still won't lift. Ideas for what to check? Have check leaks and made sure pto fully engaged,etc? Tractor is Jinma 254.
/ 3pt and Front End Loader Out #2
Check the quick disconnects where the loader plugs in. The power beyond circuit may be disconnected.
/ 3pt and Front End Loader Out #3
I agree. That is what was wrong with mine. It looked connected, but it wasn't.
Ron
/ 3pt and Front End Loader Out #4
Checking you hyd quick connects are no doubt the first thing to check if you are still running the factory connectors.
We have had some of the 2006 models have the plastic pressure relief valve break in the filter head [if yours has the external spin on hyd filter] and restrict oil going to the suction side of the pump.
Ronald
Ranch Hand Supply
/ 3pt and Front End Loader Out #5
Ronald
Ranch Hand Supply
I have to agree with Ronald here that it sounds like you have a relief issue if you lost ALL hydraulics.
/ 3pt and Front End Loader Out #6
I had this issue on my MF 1533 after I changed the hydraulic fluid and filter. It turns out the pump was air locked, and opening the bleed valve on the pump solved the problem. The manual never mentioned the bleed valve, so it took me a while to figure it out.
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
