What are some of the better brand snowblower for homeowner use. I’m looking to buy a 72” 3 point blower and wondering which brands work best. Have looked at an MK Martin seems like a nice unit.
Which one of the four models of the
L3940 mule do you have???
Does your mule have the 8 speed, 12 speed or hydrostatic transmission?
The Pronovost family has made farm machinery for 5+ decades and
they make excellent snow blowers for heavy Canadian winters.
It all depends on how much money you want to spend and how many
bells and whistles you want.
A hydrostatic transmission eats horsepower and useable torque so
don't believe everything you hear or see from an implement dealer.
A heavier weight snow blower will have thicker steel and replaceable
wear edges and adjustable skids or extremely thick skids welded to
the side weldments of the snow blowers.
The more you spend on a heavy weight snow blower the longer it will
last and it will outlast your current mules and can be used on the next
larger frame size of mule/tractor.
The issue of which snow blower works best question is as debatable as
Punxatauney Phil or Weirton Willies predictions on the coming spring
arrival time.
My personal preference would be for a Pronovost snow blower for your
mules engine frame size which would be the following units for consumer use;
LYNX 74
Regular PUMA 64
GROUP 1 P-720 P720 TRC
If you have 2 or 3 sets of rear remotes on your
L3940 that will give you the ability
to have a hydraulic chute rotation control, spout tilt control and if you have a third
remote it will let you use the impeller drum rotation mode of the P-720 TRC model
to discharge heavy wet snow left or right without plugging the snow blower.
MK Martin made the HUGE mistake of not using the identical design for thier single
stage snow blowers "as designed" by Riest Industries for single stage snow blowers
for your size mule as they use a much larger snow thrower rotor than they should
be using which translates to not having enough deliverable torque through the
drive train to provide the PTO speed to maintain the snow thrower rotor speed of
600-700 RPM in deep and wet snow. A thirteen inch single snow thrower rotor is
the best size for any single stage snow thrower under 50 horsepower.
