3PL not working after installing FEL on L3300
   / 3PL not working after installing FEL on L3300 #1
ozzydaz
Hi,
I have recently installed a FEL on my L3300 and now the 3PL is not working. I have a 3spool DINOIL valve for the FEL and connected the tank hose to the tank port on the hydraulic block as well the return hose to the 3PL on the block. I believe I need to add a PowerBeyond plug of some sort to the DINOIL valve to enable pressure to be sent down to the 3PL. Could anyone advise what part is required on the DINOIL valve to make this happen. I can't seem to get any straight answers from local dealers etc.
   / 3PL not working after installing FEL on L3300 #2
Is it a Kubota brand FEL loader that you put on? If not what brand?
   / 3PL not working after installing FEL on L3300 #3
The Dinoil valve should have 3 ports (not counting the work ports). One is the pressure inlet, one is the tank outlet and the other is the power beyond. The power beyond outlet should have a sleeve screwed into it that effectively seperates the internal passage between the tank port and the power beyond port. The dealer who sold this to you should be able to get the sleeve.
I do know that RaT has a Dinoil valve used for his TNT setup. Maybe he can add more information about it.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
