3PH Stabilizer-Custom Made-Pics
/ 3PH Stabilizer-Custom Made-Pics #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Spent a few hours of my retirement making parts for these sway stabilizers for my Mahindra 3015 tractor which had the turnbuckle style.
The heim ball joints are purchased of course.
The tires on the Mahindra are very close to the 3PH so had to put a bend in the male telescoping member as shown.
Used 7/8" inch square C1018 for it and 1 1/4" x 3/16" square tubing for the female which leaves about 1/32" total sliding clearance. (The wall is actually about 0.170" on the tubing)
Had to bevel the corners on the 7/8" square to allow for the inside radii of the tubing and also machine a small groove to clear the weld flash inside the tubing.
The goal was to keep the design as compact as possible due to very limited space when the 3PH is spread wide for changing attachments.
Had the parts zinc plated to resist rust.
/ 3PH Stabilizer-Custom Made-Pics #3
Looks great. They are very close to the tires. Is that position in the third photo pushed farthest out? Are your rims adjustable to be able to move the rear tires out some?
/ 3PH Stabilizer-Custom Made-Pics #4
That’s some awesome work. Wish I had the equipment and patients to do something like that.
Thanks guys, I appreciate the comments.
The third pic does show the link adjusted to the extreme "out" position. The nice thing about the heim joints is that the stud end is threaded (1/2"-20) so they can be adjusted to where there is not contact with the tire in the extreme out.
The wheels are not adjustable and there isn't even enough clearance for tire chains. I think some guys will put 1" or more spacers between the wheel and hub to get some clearance.
I've spent the last 50+ years trying to perfect my machinist skills but probably should have spent some of that on welding skills. :)
/ 3PH Stabilizer-Custom Made-Pics #6
I hated the turnbuckle style too. Had the pin and bar style on my old Ford. Didn't take me long to find enough close matching parts and adapt mine to pin and bar as well. Much more user friendly and worth the effort to do. In my case I was able to find parts off an earlier model and just make some changes. Yours are really nicely made I must say. The Koreans made mine... lol...
Thanks.
The location of the slot and matching hole(s) is important to allow float but still prevent hitting the tires. I guess it just needs to coincide with the hole position that allows the lift arm to be pinned in the farthest "out" position. I will say that there is a little more to positioning the holes and slot in the male and female parts than meets the eye.
I may have went a bit overboard on the number of holes but it does allow adjusting in 3/16" increments.
/ 3PH Stabilizer-Custom Made-Pics #8
Great job! Must be nice having a plating shop nearby that will do less-than-semi-load work!!
Thanks! Yes, this is the first time I've had plating done and was a little bit surprised that they would do the ten pounds or so. There is a $40 minimum but felt it was very worthwhile. Paint just doesn't stand up in an application like this.
/ 3PH Stabilizer-Custom Made-Pics #10
Great job. I love diy projects. Looks like your 50 years of honing your machinist skill defiantly worked
Thanks!
/ 3PH Stabilizer-Custom Made-Pics #13
just saw this thread and yes those are trick for adjusters. wanted a set since i had my b6200 hts. excellent job!!!
/ 3PH Stabilizer-Custom Made-Pics #14
I like the looks of them.
I will buy a pair from you and no need to plate them I will POR 15 coat them.
My Kubota L3301 has mickey mouse turn buckles on them.
:D Al
markhdg@gmail.com
You might want to get in contact with Mark Hodge at the above email address. I believe he is building telescoping stabilizers again for sale and does very nice work.
/ 3PH Stabilizer-Custom Made-Pics #16
I had enough of fighting with those stupid turn buckles every time I wanted to change, from my ballast weight to the back blade and others.
I spent the money and got a Land Pride quick hitch.
Looked at the Habor Frieght one and watched a few Youtubes on them.
Yup there cheap one bent to ruin when he got his tractor stuck in mud. Every one had the top link hook modified.
I put the quick hitch on fixed that stupid turn buckle and a 10 to 20 minute job of changeing equipment is like maybe 5 minutes if you fiddle around.
No more prying Lifting and jerking equipment to get it to line up.
Even came with bushings to change to cat 3 pins.
Instead of removing the bushings for each change I am buying cat 3 pins and just useing the bushings on the welded pins.
:D Al
/ 3PH Stabilizer-Custom Made-Pics #17
I also had a day when the snow and ice was gone and rotated my rear tires.
Went from a scary (pleats in the seat scary) 55 inch outside to outside to 63 inches outside to outside.
Almost feels like a real tractor now, can run over a frozen ball of snow now with the loader at 4 feet and not be on 3 wheels.
:D Al
/ 3PH Stabilizer-Custom Made-Pics #18
I love a good QH.
Your blade hookup could still be improved by modifying the top tower and building a stand for the blade to rest on. You could then pick it up from the tractor seat and only have to dismount to retract the stand.
Better yet, rest it on a long round of wood and not have to dismount at all. :)
I run my rear tires as wide as I can and still use the necessary attachments.
/ 3PH Stabilizer-Custom Made-Pics #19
One of thr first things I did was put blocks under the stuff that need it.
Just back into the equipment lift and go unless it has a PTO shaft needs hooked up.
:D Al
/ 3PH Stabilizer-Custom Made-Pics #20
Cool. I must have misunderstood the pics. Looks like your top link pin is not projected forward of the tower hardware. So you can back up to the blade and hook all three at the same time, lift and drive away? :)
TANK MANIFOLD (A58214)
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A61569)
1990 21ft Center...
More info coming soon (A61569)
More info coming...
