3ph receiver/carrier
   / 3ph receiver/carrier #1
Bowhunter
southwest Indiana
Kubota BX2200
I borrowed some ideas from some of the projects I've seen on this site and tweaked them to fit my needs. I made a hitch receiver for the 3ph that I can use to move trailers.
Tractor side view picture attached.
Picture of implement side of receiver.
My sprayer tank carrier. This will slide into the receiver tube on the 3ph receiver, and back off when I don't need it. I attached 3" casters to each corner for easy maneuvering.
You can see in the first two pictures that I offset the attachement points for the lift pins and top link forward of the frame. Most receiver frames I'd seen have the lift pins and top link attachment point in line with the frame. I set them forward, and they are measured and spaced, so that the frame will fit into my Speeco quick hitch should I have that on the tractor at the time. My long-term goal is to modify all my implements to fit the quick hitch, then leave it on the tractor full-time.
The upside down "T" of the frame is thick walled 2 inch square tubing. The braces are 1" thin walled square. The pieces that the lift pins and top link attach to are 1/2" thick by 3" wide flat stock.
The sprayer tank carrier is made of 1" square, and the receiver stub is thin walled 2 inch square. Bracing is just some thin 1" wide scrap that was laying around.
I'm currently have the sharp edges of the receiver frame ground down and some primer on it. Haven't made it that far with the tank carrier yet. (P.S. the carrier will be holding a 25 gallon tank.)
I'll try to add more pictures after I've been able to get it all painted and pretty. Hard to find time to work on it with 3 kids. /forums/images/graemlins/smile.gif
   / 3ph receiver/carrier #5
Looks like a good set up. I used my modular sub-soiler frame as a base for some custom forks, etc. It turned out great, but your's looks neater than mine. Just a question, can you get the receiver hitch down low enough to just roll the spray rig platform up to the hitch? Also, do you have any other implements in mind that you are planning on adding to that set up (because I am always looking to borrow ideas!!!)?
That is a very good question. I haven't had it hooked to the tractor yet to see if it will go low enough. If it won't, I'll be grinding the welds off the casters, welding in spacers, then reattaching the casters. /forums/images/graemlins/grin.gif
The main use besides the sprayer will be a receiver hitch with ball to quickly and easily move trailers around. The only other project that I might look at is to fab a bracket for the reciever tube that could hold my electric seeder. That will be a cheap solution until I can afford a larger pto powered seeder.
   / 3ph receiver/carrier #7
Nice welds too...
   / 3ph receiver/carrier #8
Nice lookin job, you should be able to move a Mack truck with that.
   / 3ph receiver/carrier #9
Not all that familiar with 3PT's, but would a hydraulic top link get that low enough? Hate to see those casters leave! Great looking job!
   / 3ph receiver/carrier #10
I've seen enough people with these 3PH receivers why are they better than the draw bars that come on the tractors? They look like something that I'll have to make just because, but what are some of the pros to these?
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
DRILLING CABINET (A52472)
DRILLING CABINET...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
CAT 973 (A47384)
CAT 973 (A47384)
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
