3ph problem
   / 3ph problem #1
michael2001
south carolina
ym1802d
i have an 1802d yanmar and after running it for about 15 min. the 3ph quits lowering....it works fine until it gets warm...with my bush hog on it slowly lowers, but with a box blade it will not....cleaned the filter and fluid and still the same problem....any suggestions
   / 3ph problem #2
not familar with that tractor, but does it have (like mine) a control for the speed to lowe 3ph implements? if it does u may have it close too much, if i close mine nothing will lower!
   / 3ph problem #3
If the tractor is warm and once you are able to lower the unit, disconect the bush hog and see if it creeps up with the control in the lowering position? /forums/images/graemlins/confused.gif
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
Husky Crossbed Truck Tool Box (A51695)
Husky Crossbed...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
1982 S&S FLATBED (A53843)
1982 S&S FLATBED...
