DmansPadge
Veteran Member
- Joined
- Oct 3, 2004
- Messages
- 1,698
- Location
- Orange, TX
- Tractor
- Kubota B2620, Toro 2000 Series Z Master
Hey guys. I have been involved in a similar discussion on another forum but I wanted to get some of the Kubota guys input. I have a B7300 and I will soon be buying a 4ft brushhog. I had asked some questions about setting the height on the brushhog. Sneakypete gave me some great info on using check chains which seems easy enough. However, I was looking through my owners manual, and noticed that there is an adjustment to change the lowering limit of the 3ph. It is simply a bolt that you can screw in or out to change the lowering limit of the 3ph. It is located just to the right of the lift arm. The only guy I know that has a tractor like mine is Sneakypete and he said he has never tryed using it. I was wondering if anyone else has this option and ever uses it? I know I would have to adjust it from implement to implement, but, once I put on the brushhog it will stay on for extended amounts of time so I'm not worried about that.
Thanks!
Thanks!
