jmc
Elite Member
- Joined
- Jul 21, 2003
- Messages
- 3,106
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello,
Tweaking the height of the lower links while hooking up attachments is a pain because its hard to reach my control handle standing on the ground behind the tractor. If you're on the right side, you can stretch for the handle but if you're on the left, you have to stand on the links and still stretch to reach it. This project was to add a second control handle that is convenient to reach from the back of the tractor.
The attached picture is taken from the back of the tractor, facing forward, along the inside of the right rear fender. The blue horizontal stepped shaft is the 3PH control shaft. The blue original handle is welded to its right end and that handle goes up thru the slot in the floor. Also attached to the control shaft is the shiney new second handle. (the only clean part on the tractor). The handle is about 15 inches long and extends to within easy reach of the back. The next post is a wider angle of the same view.
John
John
