s78wingrider
Thought I would share this- I finally broke one of the bolts that hold the swing chains and when I did it broke 1 piece of 1 of the links. If anybody has dealt with the maker's of these hoes, you know all they want to sell is a complete unit of whatever you need when you only need a small piece! I could not find exact part but found that #100 links will work. bought 2 master links for 5 bucks. It didn't matter that they were longer since broken link was right on the end. After reinstalling I noticed that since chain was wore, the swing cyl. was turned down so it could wear the chain out faster! I then mounted a piece of angle across under lower chain block to keep cly. level with chain. Only had to drill 2 holes, was not a hard install, works fine, there is really no pressure on the angle. Also when I had it apart, found that 2 more of the bolts were broke and 1 was bent. This hoe is on a 3215 gear, you would not believe what I have done with this machine!!! Aaron
