370D greasy soot in intake manifold - normal?
   / 370D greasy soot in intake manifold - normal? #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I,m the guy who still has not started his 370D. In my last post, I stated that I was going to put in fresh fuel with cetane boost and half can Restore to try to improve ignition and compression without tearing down the engine. I pulled the tractor started with my Kubota and let the engine run for 2 and a half hours. It ran smoothly and had plenty of power to get up hills in highest gear. But it still will not start on its own. Cranking speed is good - much better than the videos of engine shown with 16 pages of replies. It just cranks with puffs of black smoke without catching. I have not yet purchased a compression tester but I am pretty sure that I will find that it is at least marginally bad.
I pulled off the big rubber hose to the intake manifold. The inside of the hose and metal intake manifold had a heavy coat of oily soot. Is this normal for a diesel? This tractor has two rubber hoses - one from the filter to a midpoint above the engine and one from that point to the intake. When I bought the tractor, the first one had a big hole from dry rot. Is it possible that a chunk of rubber from the hose got sucked into the engine, got burned up, and is now burned into a deposit on a valve causing bad compression?
I pulled off the valve cover and all but one of the valves had consistent lash of about .010. The odd one was about double. Could this valve have a deposit that leaves a compression leaking gap? Would this cause the oily soot in the intake?
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
