3600, loader hates the cold
   / 3600, loader hates the cold #1
petebert
Outside of Ann Arbor
Really tough to get to my loader to move when temps are near freezing or below. The loader fluid is shared with the rear end only, right? Transmission is independent? I checked the fluid, it only has about 20 hours on it and the level is still good. I use my tractor every day to empty manure from the barn. I have to wait a couple minutes to get the main arms to move at all so I can drive. Tonight when I went out it was probably 15 degrees out and it probably took 5 minutes for the bucket arms to fully extend to dump it.
   / 3600, loader hates the cold #2
What does your 3ph do?
Probably just needs to warm up. Or you could replace with more appropriate fluid?
   / 3600, loader hates the cold #3
Does the loader use the tractors hydraulics, or does it have a separate crankshaft driven front pump?
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
UNUSED SDLANCH SDLL80 LOADER (A57192)
UNUSED SDLANCH...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
John Deere Hay Spear (A56469)
John Deere Hay...
2015 FREIGHTLINER CASCADIA SLEEPER (A57880)
2015 FREIGHTLINER...
