3540 no running lights
/ 3540 no running lights #1
1969grandpa
Bronze Member
Belton, SC
Kubota L3540
I was on my 3540 at night for the first time and noticed that when I turn the lights on, only the head lights come on, no rear lights at all. The turn signals and hazard lights work fine. Is this normal or should I have running lights too? My buddy says his JD 790 has running lights.
/ 3540 no running lights #2
You should have running lights. Check at the lamp socket... should have 2 wires, one for signals and the other for running lights, ground is through the mount to tractor frame. Follow the wiring, it may have been damaged or unplugged. KennyV
/ 3540 no running lights #3
You have them, because my 3540 does. Check as Kennyv said they are there.
DevilDog
Thanks guys. I thought it should. I'll check when I get home and let you know.
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
Mayrath 10" x 34' Truck Auger (A66285)
Mayrath 10" x 34'...
LOOK! (A63111)
LOOK! (A63111)
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
6ft Metal Star (A65583)
6ft Metal Star...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
