353H Glow Plugs
   / 353H Glow Plugs #1
Kirvam
Tomah WI
TYM T353H
Having an issue with my Glow plugs. There is a bar that connects the front Two cylinder glow plugs then a break in the bar and another bar that connects the back two cylinders glow plugs. There are wires that go to each bar that are connected to the glow plugs. Should there be a break in that bar?? Also when I put a volt meter on the front bar I get voltage when I put the volt meter on the rear bar I get Zero volts. Any advice would be great.
   / 353H Glow Plugs #2
I took a look at my plugs and they are connected in pairs only, there is a break in the center. I can't help you with the meter question. Did you ever get this resolved?
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
MONOSEM NG-3 LOT NUMBER 262 (A53084)
MONOSEM NG-3 LOT...
JOHN DEERE F725 LOT NUMBER 91 (A53084)
JOHN DEERE F725...
T3 Motion Patroller Segway (A51694)
T3 Motion...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2025 INDUSTRIAS AMERICA FT510 5'X 10' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
