3520vs 2320
   / 3520vs 2320 #1
bunson
Hamburg ny
JD 3520
I currently have a John Deere 2320 with a 62 inch deck,loader, 3 bag bagger and turf tires. I want to upgrade to a 3520 with a 72 inch deck. No cab. Most of its use will be for mowing. My question will be it be too much extra weight (1000# more)on the lawn. What tires are the best turf or r4's? I will get another loader for the 3520 but it will be used for moving snow piles, stone and lifting things up to my loft in my garage. This loader will lift a foot higher than my current one and has more capacity. I am a home owner with 12 acres.
   / 3520vs 2320 #2
A 3520 is getting heavy for mowing. Turf tires will be easier on the grass.
Sent from my GT-P3113 using TractorByNet
   / 3520vs 2320
How many people use a 3520 for mowing? What is your experience mowing with it? Too Heavy?
   / 3520vs 2320 #4
I've used a Deere 4400 (which has very similar specs to the 3520) for mowing with a 72" RFM behind it. No problems here as long as you use some common sense.
   / 3520vs 2320 #5
The lighter you are for mowing the better off you are going to be. I know bigmike50 mows with a 3520.
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
UNUSED BB500 DUSTLESS BLASTER (A51248)
UNUSED BB500...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
MURRAY 21" GAS MULCH OR BAG PUSH MOWER (A51248)
MURRAY 21" GAS...
