3520 300CX hose routing
/ 3520 300CX hose routing #1
jmt1271
Platinum Member
MO
Kubota L2501
The lines from the 300CX to the 3520 are chafing the side of my hood. Not the end of the world, but wonder if there is a way to prevent it. What do you all do to minimze this?
/ 3520 300CX hose routing #2
The lines on my 300cx are bundled inside a black mesh protective enclosure as they pass by the hood. This is the way that the 3320 was delivered. No sign on a problem.
Mine are in the mesh as well. The problem is the mesh is against the side of my hood, right side, near the front wheel. As the tractor moves and/or I lift the loader arms, it rubs against the hood. It is scuffing the plastic.
/ 3520 300CX hose routing #4
Jason, I'll try and send some pics in the next couple of days of my 3520 w/ 300CX loader. The hoses are close,but not rubbing. Rubbing the hood would be unacceptable to me. Try and tweek the hoses by disconnecting them and putting a twist in them so they want to push away from your hood.
Lookimg forward to the pics.
/ 3520 300CX hose routing #6
I used a large zip tie and pulled them closer to the loader. Zip tie can be cut if needed. Easy fast fix. Got large zip ties from Menards. You could also connect zip ties end to end if have smaller zip ties to make a longer one.
/ 3520 300CX hose routing #7
My 300CX has black plastic retainer clip gizmos that tie the bundle to the loader arms. The clips snap into small holes in the loader.
Mine is clipped also. But it still gets against the cab. I was wondering if mine is routed improperly.
I said cab, but meant it gets against the hood. I only wish I had a cab.
/ 3520 300CX hose routing #10
I hadn't noticed any problems on my 3120 w/300cx, but I just checked and where the mesh is held in place against the inside of the lifts' arm I can see where the plastic clip is just touching my hood. It may be this clip can be tighten up a bit to provide clearance, since it doesn't feel very tight.
/ 3520 300CX hose routing #11
"The lines from the 300CX to the 3520 are chafing the side of my hood."
My 3520 - 300CX came with the same problem. It was caused by 2 things. First the upper hose bracket was bolted tight to the arm not letting it swival like it is suppost to. And second when the hoses were attached the installer did not make sure that all quick connect ends were pointed up as the book calls for. Once these were corrected all was well.
Al
/ 3520 300CX hose routing #12
Jeff, emailed you pics of how to remedy problem.
/ 3520 300CX hose routing #13
Say Dirtworks,
I'd like to see those pics too, if you don't mind. My baby hasn't been delivered yet but that's the configuration I ordered. I could head a potential problem off at the pass. Would appreciated it.
/ 3520 300CX hose routing #14
My hose connections were pointed up, but in examining the plastic tie wrap that holds the meshed bundled against the inner arm, I could see that if repositioned it would give me the clearance needed. I didn't need to loosen the tie wrap, the ends of the plastic clip that wraps around the mesh were butting ends and not overlapping. As soon as I gave the clip a gently squeeze, they slipped by one another, and I was easy then to reposition the tie wrap so its away from the hood. I now have about 1/2" clearance. Hope my pictures help??
Great pics Hankus. But my problem is different. I dont have any clips touching the hood. My hoses(inside the mesh wrap) are touching my hood toward the front, just above behind the front right tire.
/ 3520 300CX hose routing #16
JMT are your hose connections pointing up as mine? If so then the only other thing it can be is the positioning of the hoses in the clip along the inner arm. Maybe the mesh hose bundle needs to be pulled through a little more to reduce the size of the loop that hangs below it. I'll see if I can get a better picture of the mesh as it passes the hood on mine to give you an idea of how much slack is present.
/ 3520 300CX hose routing #17
jmt1271
Try a simple test to see if you need to do a little work on the hoses. The next time you have the loader off lay the lines out behind it. Pull the pin on the mid bracket so the lines are straight out. Two things to check now. 1, are the connectors on the ends pointing up? 2 are the lines free to move in the sleeve?
If the lines are not free to move in the sleeve, cut the plasic ties to free it. My service department said the sleeve should not have more ties than the book shows and they are not to be to tight. The only ones that are tight on mine now is the first one before the fold and the second one that is weaved into the sleeve.
If the ends are not pointing up ( mine were pointing down) cut the plastic ties if you did not have to do it to free the lines, and slide the sleeve back until you can loosen the ends of the hoses under the upper sleeve end. Not to much here. Just enough to rotate the ends up. You may have to go a little past because the end will move a little as you tighten it up.
The picture is the way the lines should look when you are done. They do not contact anything but the loader arm.
Al
2016 Ford F-550 Ext. Cab Enclosed Service Truck (A61573)
2016 Ford F-550...
Willmar and AgChem Parts and Service Manuals (A63117)
Willmar and AgChem...
Caterpillar 966G/972G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
2 Wheel Homemade Trailer (A64119)
2 Wheel Homemade...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
