3510i Will not move
   / 3510i Will not move #1
mrnobody
Hey Guys,
I loaned my tractor to a friend this past weekend and when I received it back I noticed that the clutch was slipping when I was moving some dirt around. Today I tried to adjust the clutch sleeve and can't get the tractor to move front or backwards. Does this sound as the clutch is completely out? Thanks in advance for any help.
   / 3510i Will not move #2
Start by seeing if you can adjust the clutch rod until you have about 3/4" to 1" of freeplay in the pedal. I say this just in case your friend messed with it and you are all out of whack on adjustment.
But if you can't get the clutch to work by adjusting the clutch rod linkage, it sounds like your clutch might be shot. Not an simple chore on a Branson, and not cheap either. Hope it is something easier.
   / 3510i Will not move #3
sounds like you might have adjusted the clutch the wrong way
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A53426)
2023 MAXEY G8X...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
Unused Delta Crash...
Boat motor turns (A51694)
Boat motor turns...
