3510i Specs
   / 3510i Specs #1
redfoxco
Branson
Does anyone have the gear ratios for the 12x12 trannys that come in the Branson 3510i?
How about engine performace curves (HP and TQ)?
Thanks...
   / 3510i Specs #2
Redfoxco, can't find ratios from Branson. They have kilometers per hour in the specs, but I got these MPH from the Century manual. I couldn't get the spreadsheet to post exactly as I'd like, but the first column is the speed number, the second is MPH forward, and the third MPH reverse:
1 1.05 1.00
2 1.23 1.17
3 1.64 1.57
4 2.31 2.21
5 2.56 2.45
6 3.00 2.87
7 4.03 3.85
8 5.67 5.42
9 6.16 5.90
10 7.23 6.91
11 9.69 9.27
12 13.64 13.05
As jar as the power & torque curve goes, I'm trying to find that out myself (earlier post). Hope this helps and good luck on your search.
   / 3510i Specs
Thanks, KYMike. I crunched the numbers you provided and found the range selector gear box ratios. If you take your reference to be high range...
Mid range is 2.4:1
Low range is 5.9:1
The mid and low range gears multiply the transmission input shaft torque and speed values by the above numbers. This assumes that high range is 1:1, which it may not be -- does anyone know?
UNUSED INDUSTRIAS AMERICA F08 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2020 COLOMBO TM LOT NUMBER 202 (A53084)
2020 COLOMBO TM...
(APPROX 26) 2" X 6" X 78" THICK TUBING (A51247)
(APPROX 26) 2" X...
40ft Shipping Container (A52377)
40ft Shipping...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
