3510 tractor
/ 3510 tractor #1
jarbill
Bronze Member
Can anybody tell me what major differences there are between the 3510 and the 3215 tractors? Also, does anybody have any personal experience with the 3510 as opposed to the 3215 or know of any particular problems with either one? Lastly, if anyone knows, what is the price difference between the two?
Thanks in advance.
Jerry in Texas
/ 3510 tractor #2
3215 is made by Mitsubishi in Japan. Much lighter tractor than the 3510. The 3510 in made by TYM (Tong Yang Moolsan) in Korea and it is a much stouter tractor than the 3215. Both are nice.
/ 3510 tractor #3
There will be roughly a $3K price difference between the two with the 3510 being the more expensive one.
/ 3510 tractor #5
MLinOleMiss said:
10 series has cooling issues.
I have never had a 3510 in my shop for a cooling issue.....
I have one that we rent out with a 72 cutter on it and never had an issue.
Maybe you have an isiolated issue.
/ 3510 tractor #6
The 4110's have had some cooling issues, and here in the north I have had no 4110 cooling issues. I have not seen or heard of any cooling issues on any of the other 10 series tractors.
/ 3510 tractor #7
If you keep the screens in front of the radiator clean, it doesn't heat up. If you don't clean the screens, temp will go up quite a bit-but I think that's with all tractors. My sister's kubota is the same way.
The 3510 is heavy enough to do some real work. I'm guessing it is close to or over 6000# with FEL, backhoe undercarriage and loaded tires. I like mine!
/ 3510 tractor #8
Not going to rehash all the problems that I have had with my 4110, If you want more explanation, search my posts, have had cooling issues going on two years with my 10 series.
