3504 KIOTI CLUTCH PROBLEM?
/ 3504 KIOTI CLUTCH PROBLEM? #1
HARKNESS
Columbus, Ohio
I bought a used Kioti 3504 with 370 hrs. When I bought the tractor the previous owner said he had to replace the cluch and the new one had only 20 hrs on it. After 10 hrs of use the tractor stopped moving. I took the tractor to a Kioti dealership and they ended up replacing the clutch and pressure plates. After mowing for 6 hrs the tractor stopped again. Looking for any suggestions on what could be causing this problem.
/ 3504 KIOTI CLUTCH PROBLEM? #2
Sorry to hear about your problem.
Also sorry I'm of no help, because I have no idea what is causing your problem.
I do hope it gets resolved so you can start to enjoy your machine !!
/ 3504 KIOTI CLUTCH PROBLEM? #3
One question. Do you smell anything when you are mowing?
I do not remember anything smelling unusual at the time. What would be the problem if there was a unusual smell? Thanks for the help.
/ 3504 KIOTI CLUTCH PROBLEM? #5
If the clutch was actually being used up (the faces being worn out) that quickly, there would have to be a burn smell. Did you get to see the clutch, that they removed the last time? If there wasn't a burn smell, there MAY be as hub problem on the disk. It could have the wrong center or even be put in backward. You would have to see the disk, to be able to make that determination.
When I took the tractor in the first time they showed me the clutch. The clutch was actually ripped off the hub, the rivets holding the two together were all rounded out. Also they found a bolt that and fallen off a finger? I was hoping by taking it to a dealer that they would know how to repair/install it correctly.
/ 3504 KIOTI CLUTCH PROBLEM? #7
Sounds like they are using the wrong disk or pressure plate.
1997 FRAC TANK 500BBL WHEELED (A68842)
1997 FRAC TANK...
PORTA POTTY (A67714)
2021 HLA 20LA04504 Concrete Chute Bucket Skid Steer Attachment (A66734)
2021 HLA 20LA04504...
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
Ez-Go Freedom TXT SE Electric Golf Cart (A64912)
Ez-Go Freedom TXT...
