bob2299
Bronze Member
- Joined
- Dec 14, 2010
- Messages
- 67
- Location
- Canada Northern Ontario
- Tractor
- Bobcat ct230, 35 hp Massey Furgeson 3Cyl Diesel
Hello I am missing the drain plug located on the left rear side of the tractor, It is the plug that you would use to drain the Hydraulick fluid from the Transmission Hydraulic Case, it is just bellow and to the right of the PTO lever
Any one know if it's just a Pipe tread plug and the tread size? or if it is a bolt, what tread is it, I have tried every thing i have here on location and cannot find any thing.
or even if you have the Parts number......
Also I would like to get the big fill plug, that one is located on top of the trasmition just left of the Shift lever, same if you can tell me the Part number
thnx
thnx
