35 Acres and a Tractor
   / 35 Acres and a Tractor #1
JHWacktor
Albion, IN
Ford 3400 Industrial
I'm Jim. I bought 35 acres in northeast Indiana about a year ago. Its a beautiful piece of land with a variety of terrain on a small fishing lake. It's near a town called Albion.
When I purchased the land, I knew I needed/wanted a tractor to maintain it. I started looking at 8Ns but eventually found a Ford 3400 industrial gasoline tractor with a "bush hog." Its a lot of fun to run when it runs. And when it runs, it really runs but when it doesn't, it sputters and is useless which is why I've joined this forum. I'm looking for advice on my issue which seems to be triggered when I add new gas. I found an PDF version of the service manual but it doesn't seem to have enough detail so I'm hoping there's somebody out there who has some experience with the gas version of the 3400.
Thanks for listening.
   / 35 Acres and a Tractor #2
I suggest you copy your post into one of the FORD specific forums.
Hit the FORUMS key at top of this page, then cursor down to the FORD forums.
   / 35 Acres and a Tractor #4
:welcome:
To the TBN forum Jim. We are glad that you joined us here.
You have come to the right place as there are many experts here that will be happy to help.
As Jeff said, if you post your problem in the Ford forum, you get your answers quicker.
   / 35 Acres and a Tractor #5
:welcome:
Welcome to the forum!
I'm going to move your thread over to our Ford vintage tractors section to see if we can find you someone with experience with the 3400.
   / 35 Acres and a Tractor #6
:welcome: to TBN Jim...enjoy.
   / 35 Acres and a Tractor #7
First of all welcome to TBN - lots of folks here filled with knowledge (I'm not one of em - that's why I'm here lol)
I've no experience with the 3400 but just general troubleshooting this would lead me to think some type of rust/dirt/sediment in the fuel and/or water that is getting stirred up when new fuel is added and causing flow problems.
Take a look at your manual and see if there are any sediment bowls, fuel filters, etc and make sure they are all clean and free of water / air bubbles / crud or anything else that could interrupt fuel flow.
That might not be the problem but it's a good place to start & it will keep you busy till one of the experts comes by. :D
Best of luck
   / 35 Acres and a Tractor #8
Sounds like points to me but I'd give it tune up. Plugs, wires, points, cap, condenser, rotor & FF before I went any further. I haven't had any luck with aftermarket points. They all burned up in 3-4 months. I put the NH points in about 2years ago and all is still good
Two more good thoughts - sediment and/or water and points & a tune (along with the NH endorsement). Adding both to my list of next things to try - I appreciate the insights, men. Thank you.
   / 35 Acres and a Tractor #10
No need to guess on points, check spark first.
Points on 3000 models are a hair of a PITA to service.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52128)
2014 Dynapac...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
2007 KENWORTH T800 DUMP TRUCK (A51243)
2007 KENWORTH T800...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
