3400 FEL water pump replacement
   / 3400 FEL water pump replacement #1
jls3
Southwestern Ontario, Canada
Ford 1200 FEL, Ford 3400 Industrial Loader
I'm replacing the water pump in my gas 3400, I'm rcoring the rad and cleaning a few things up. The problem I'm having is getting the room to remove the fan belt due to the front mounted hydraulic pump. I've unbolted the flange at the crank and unbolted and rotated the union at the pump. Does either the flange or the union need to be removed off the shaft. I've thought of loosening the pump but don't believe that will help.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2021 Deere 333G (A53317)
2021 Deere 333G...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
