VernLPoole
- Joined
- Jul 20, 2020
- Messages
- 13
- Tractor
- Ford 1710, Bobcat 337
Nearing retirement and having a 15 acre sandbox plus neighbors with many more acres available for potential playing, I finally bought myself a used excavator: 2005 Bobcat 337. I did some dirt work in my 20's, Cat D3 dozer, John Deere backhoe, etc, and have owned a small Ford tractor for years, but the hydraulics on the Bobcat are orders of magnitude more complex than anything I have worked on, so I'm not even sure if the symptoms I'm getting are a problem or are normal. Hoping someone here can help me clarify that and maybe steer me toward what to do if there is a problem. I'm reasonably handy and prefer to fix things myself if I can rather than spend a lot of money, especially since I'm not really generating any income from the machine.
So the symptom is that sometimes the hydraulics get very weak/sluggish below about 1500 rpm. I believe it may be related to temperature because it seems to happen after about 20 minutes of operation, though I can't be sure that's not just coincidence. The last time it happened I put a gauge on the test port and sure enough,at idle the pressure was something like 2200, and if I slowly increased the rpm, the pressure jumped up to normal (~3500) when it reached about 1500 rpm. I have the service manual and am slowly gaining some understanding of the system, but there's not much information about nuances of how things are supposed to behave, or maybe I'm just not understanding the information that is there. If that's how it's designed to function, I can run the machine at higher rpm, but much of the work I'm doing is easier with a light touch: setting stones in a wall, fine grading along a driveway, etc. Any thoughts?
Thanks in advance for any insights you can offer!
