336D loader
   / 336D loader #1
Vern
Good evening
Loader started dropping the bucket today. Bucket will just start dropping and very quickly. Looking for some where to start looking for the problem. Have a joy stick control. Was wondering if it could be the quick disconnet leaking by, I had an o-ring come out of the ball on one when I first bought it.
Vern
   / 336D loader #2
If it's just the loader & not the 3 pt. Look for loader valve bypassing . Disconnect the qc in question with loader raised & see if hyd fluid leaks out. My guess is loader valve seals or trash in the valve
   / 336D loader #3
Here is a theory. raise the bucket all the way. Kill the tractor. If the bucket falls part of the way to the ground and stops you have a bad lift cylinder. If it falls all the way to the ground you have a bad control valve. May be a stupid theory but free to try. :thumbsup:
   / 336D loader
Killed the tractor and the bucket dropped all the way, took off the discconet and no oil leaking. Guess I will take the control valve in for rebuild.
   / 336D loader #5
Its been awhile Vern but I am 99% sure all there is inside one is o-rings and springs and they will be plain old o-rings. A careful tear down real careful attention to detail and be real clean about it and do one valve at a time.
I bet you can do it yourself I know I would try that first before trusting anyone else plus I am a cheapskate diy type. Even if you tore into it and found it had lip seals I bet a kit could be bought if the numbers are still on it. my .002
2023 JACTO ARBUS-1000 LOT IDENTIFIER 261 (A53084)
2023 JACTO...
Cat TH407C Telehandler (A53472)
Cat TH407C...
UNUSED JCT 84" HYD 4N1 BUCKET (A51248)
UNUSED JCT 84" HYD...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
