335 JD Hydraulic tie is not returning home
   / 335 JD Hydraulic tie is not returning home #1
AL04
MF 360 MF245 Cub
I just purchased a JD 335 hyd tie with 2 twine arms, having trouble out of the arms not working smoothly. In the return home, can also feel a vibration in the tractor hyd lever when it does not wont to return home. Also see some hyd fluid coming from the twine cyclinder
   / 335 JD Hydraulic tie is not returning home #2
Welcome to TBN
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
3 Forks (A56857)
3 Forks (A56857)
