Loader 32la New Holland Loader
   / 32la New Holland Loader #1
koamfps
Michigan
NH TN70DA & NH 2120
I have the above loader on my TN70DA
I can raise the bucket with a load and lower the bucket without a problem.
I can tilt the bucket down without a problem. When I try to tilt the bucket up with a load it will not rise.
Scenario. I have a perfect II field cultivator that weighs 960 pounds I put a chain on the bucket to lift it off of the trailer everthing was fine. however when I wnet to bind (put tension on) the chain by tilting the bucket up.
It would not lift up... (tilt up)
Fluids have been checked and are fine.
PS My little 2120 NH lifts this all day with the bucket... So I guessing something isn't right. I bought the TN70 used in February
Any help or thoughts would be greatly appreciated.
   / 32la New Holland Loader #2
Most likely a maladjusted cable that controls the valve spool in question, or a faulty quick coupler on the hose leading from the bucket cylinder base end port. Could also be a faulty piston seal in one of the bucket cylinders.
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2008 INTERNATIONAL DURASTAR 4300 SERVICE TRUCK (A50854)
2008 INTERNATIONAL...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A49461)
2005 International...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
