.325 for Husky Rancher 55
   / .325 for Husky Rancher 55 #11
I'm not surprised the Stihl outruns the Husky. I have an 023 with narrow kerf chain that cuts circles around my Husky 242.
The 55 Rancher isn't enough saw to effectively pull a 3/8 chain in my opinion. The more wood you pull out of the cut, the harder the saw has to work.
I have a 262 XP Husky, an 044 Stihl, and the two I mentioned before. Only the two bigger saws have 3/8 chain, the others have .325. The 262 and 044 are true pro saws, lots of power to pull the larger cutters.
If you're going to go with .325, I'd recommend Oregon's 30 series chains, all are "low load" chains for lack of a better term. The 20 series are so-called professional chains, but put more load on the saw.
Sean
Do you want to get rid of your 242? They are really hard to find anymore around here (in decent shape anyway). When the 262 (perhaps the best small firewood saw ever made as far as power to weight ratio goes) gets on your nerves, I would be interested in it too, it's an old design, but a great saw. The 242 was a great limbing saw (again, old design but great little saw), spins up quick like the 346's of today. Trust me, the 55 will pull a 3/8 set-up with ease as long as you keep the chain sharp and you don't lean on it, after all it's only a 3.2hp saw. Sounds like the OP has his mind made up about the .325 chain, so maybe we can get a hands on field test once the swap is made.
   / .325 for Husky Rancher 55 #12
I've had the 023 for a few years now, it was a free refugee from the junk pile that got a rebuild and a new lease on life. I was really surprised how much power it had for a small saw, I expected it to be a dog next to the 242.
The 262 is an inheritance kinda thing, you might say I wandered into it. Great woodpile saw, I don't like it for felling and limbing.
The 242 was another refugee, it was a "problem saw" the dealer couldn't find out what was wrong with. It took me a while, but it works well now.
The 044 is the racehorse in the stable, next to the 262. Both cut fast, but the 044 has impeccable manners and loads of torque. Another refugee, I got it for $25 in two big cardboard boxes that had enough parts to build one complete saw out of two.
I think I bought one new saw in my life, a Jonsered back in the late 80's.
The new stuff is largely junk, I wouldn't mind getting a 353 or 346, but don't really need one. Maybe an older 028 or 036 just for the **** of it.
I'm a believer in the small chains, faster cutting and less vibration. It didn't make such a difference in the old days of slow turning saws with lots of torque. The new (90s and on) saws are faster turning, not so much brute power. They can really take advantage of the small chain. Maybe a little less durable in heavy cutting, but great for guys like me.
Sean
You may want to pull the muffler & see if you have scoring on the P&C, these saw's will run (and sound fine) down to around 110psi on a compression guage, but that is about 40-50 psi from where they should be. Is the saw 4 storking @ WOT? I really think you have more of a problem than just chain size to allow the 250 to outcut the 55.
It is 4 stroking at WOT, I haven't pulled the muffler. Might give that a whirl next, the Husky has had about 10 tanks of fuel through it and the Stihl has had 2 tanks so neither one should be worn out yet but you never know.
I'll check it out and see what it looks like.:thumbsup:
   / .325 for Husky Rancher 55 #14
Saw life should be measured in decades for most of us, although I know pro users can go through a saw in a year or less with hard use. Everything I have has been around for at least 15 years or longer, and still running strong. I've replaced seals and bearings in them all, but the cylinders and pistons are original, the 023 got a new ring because I broke the old one removing it.
Fuel-air mix is critical to long life, as is a good air filter. Dirt and lean running destroys more saws than anything else.
I usually set my high speed screw so the saw is just starting to really clean up and scream at WOT unloaded, then slowly back it out until the exhaust note gets that four stroke "mumble" or "burble". It should clean up when in the wood, and the plug should be a light tan colour after a long WOT cut.
Tuning issues aside (if any), I think you'll see better performance from the 55 with a .325 chain, particularly with a narrow version of that size.
My 242 has a 20 series .325 Oregon chain, and if the depth gauges are set according to Oregon specs, it's too much chain for the saw in my opinion.
The 55 should have enough power to handle a 20 series chain no problem.
Sean
   / .325 for Husky Rancher 55 #15
I would agree. A 55 cuts much better w/ .325. You will need a new bar and sprocket with the bar matching the gauge of the chain. I wouldn't go beyond 18" for the bar on these.The current 357 is much like the old 262's made with a lighter piston assembly to build revs.
Just an update but I went back to a original Husky 3/8" chain and it made a huge improvement:thumbsup: I think my larger issue was running a full chisel chain more than the pitch of it, the saw is cutting very well now and although the Stihl likely would get the edge in all out speed for cutting the Husky is cutting great and acts like I remembered. I looked at the piston and it looks good so I think my saw is in OK shape, I've owned it since new and it hasn't been run to death so I'll stick with a less aggressive chain and take what it will give me for performance and be happy.:D
   / .325 for Husky Rancher 55 #17
A 55 will pull a 3/8 th pitch. It is a different saw with .325. One day you might want to experiment and you'll see for yourself.
I'll try one down the road, I've got to get another bar and possibly rim sprocket for that but one day I will try it.
   / .325 for Husky Rancher 55 #19
Yes, I changed mine over a couple years ago. Huge improvement in cutting speed. Changed it from a saw that you didn't want to run to one thats fun to run. Steve
Terms & Conditions of Auction (CHECKOUT DATES) (A59213)
Terms & Conditions...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
