3225 Brake ignition switch
/ 3225 Brake ignition switch #1
77Shovelhead
Las Vegas, NV
Cub Cadet 3225
Hi all,
My 3225 stalls out when I remove my foot off of the brake pedal. The pedal needs to be depressed fully to start but should continue to run. Trying to find the switch to see if it can be bypassed. Tough to figure out without a service manual. Any one have any experiance on this problem?
It's funny I just installed a new carburator the other day and it worked fine. Now a new problem. I pulled off the deck since I moved back to Las Vegas, I don't use the tractor for cutting anymore. I do use it for hauling stuff around the property.
Thanks for any help!
As usual when you break down and ask for help you find the solution on your own. The switch was located nearly in the center on the bottom of the frame beween the deck and chassis. The switch appeared to be working ok electrically when i checked it with a VOM. I fashioned a set uf jumpers and all works well now.
