3204 electrical problem
/ 3204 electrical problem #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
My dad's new 3204 is blowing one or both 20 amp fuses. The tractor is new and under warranty but I think the problem may be hard to track down. I was hoping the dealer has a tech bulletin on this problem or had seen it before. Anyone else had any fuse problems. I know the ignition fuse was blowing, not sure what the second fuse is for.
Curt
/ 3204 electrical problem #2
Curt, check around under the hood for any wiring close to the engine. I know on my new 2544 (similar under the hood to the 3204), I had to re-route, bundle, zip-tie and organize some of the wiring or it would have burnt against the HOT engine for sure. I still need to address the headlight wiring better, I dont see how anything up there will hold up long term to the heat /forums/images/graemlins/mad.gif.
G/luck
Joel
Hey Joel,
I think the dealer is picking up the tractor today. I'll post again when they find the cause of the problem. If the tractor was out of warranty, I'd probably try a 10% bump in the fuse rating. Dont know if they make anything between a 20 and 25 though...
On my 5252, I noticed yesterday when I checked the oil, they had used a a stick on type cable tie to attach the headlight harness to the hood. It is of coarse hanging free. I need to take a closer look at that now that you've reminded me of the heat issues. Overall, I love the 5252, it's a Cadillac to mow with.
Curt
The Cub dealer delivered my dad's Cub on Saturday. They had it for the fuse problem. When they delivered it, it wouldn't start, blown fuse. put the spare in, blown again. It's back to the dealer for another round of troubleshooting.
Curt
/ 3204 electrical problem #5
</font><font color="blue" class="small">( The Cub dealer delivered my dad's Cub on Saturday. They had it for the fuse problem. When they delivered it, it wouldn't start, blown fuse. put the spare in, blown again. It's back to the dealer for another round of troubleshooting.
Curt )</font>
I would really be upset with the dealer in this case...its just plain sloppy lazy workmanship, to not even double check if it starts, and i would question if they even bother to touch it....
Totally unacceptable, I would be looking elsewhere for service....no excuses for that except incompetence..... /forums/images/graemlins/frown.gif
Sorry to hear about your troubles....the 3204 is a very robust unit, never heard of any electrical problems like yours....
keep us updated
Ducati
/ 3204 electrical problem #6
Curt: Go back to page 4, this forum. Check my post dated 5/16/2005. This is the same problem I found on the 2544. Also added a double stack heat shield to the horizontal exhaust pipe to stop overheat to right headlight. Jerry
/ 3204 electrical problem #7
The wires are routed better on the 3000 series, and its not really an issue with them. However its not to say its not causing a problem on your machine, somewhere somehow.
Duc
My dad called tonight and said the 3204 smelled really hot and he odor seemed electrical. He said it was also smoking significantly from the exhaust with an oil smell. We checked the oil and it was overfilled slightly.
It didn't make a difference turning off the PTO. He parked it and called me and then discovered it had started started leaking gas again also.
Anyone had any experience trying to get the dealer to just replace a tractor due to repeated service issues?
This will be the fourth shop visit since April.
Curt
/ 3204 electrical problem #9
</font><font color="blue" class="small">( My dad called tonight and said the 3204 smelled really hot and he odor seemed electrical. He said it was also smoking significantly from the exhaust with an oil smell. We checked the oil and it was overfilled slightly.
Curt
)</font>
Is this after the electrical problem from just a few days ago?
Can your dealer be that bad? they drop off a machine that never started, and probably they didnt work on it to begin with...
Now more electrical problems? along with gas leaking?
How old is the machine? did you buy it new? is it under warranty? How upset are you so far? you might want to raise the noise level....
Duc
It was brand new in April, it probably has 20 hours on it. It is under warranty until 4/07. I'm beginning to suspect something is really wrong with the service department there. It was in the first time for a gas leak and the low fuel light not working, the second and third for the fuse blowing problem and now a gas leak and electrical problems.
Thi is one of the two new tractors I bought at their auction in April, but they were sold as new with full two year warranty.
My dads going to stop tomorrow and talk with them. He's in his 80's but knows bad service when he sees it won't hold back when he talks with them.
Curt
/ 3204 electrical problem #11
</font><font color="blue" class="small">( It was brand new in April, it probably has 20 hours on it. It is under warranty until 4/07. I'm beginning to suspect something is really wrong with the service department there. It was in the first time for a gas leak and the low fuel light not working, the second and third for the fuse blowing problem and now a gas leak and electrical problems.
Curt
)</font>
You should go with him...You dont want him upset and the dealer telling two different stories -one to you and another to your dad. Is there another dealer in the area? start a relationship with them fast....
The 3204 is a rock solid machine. I never heard of anyone having the amount of problems you have.
Duc
Duc,
I wanted to go also but I couldn't get there till the weekend and he wanted to get this resolved.
They didn't really offer much, they said the 3204 has been a really solid tractor. They suggested since it was bought at auction they couldn't take it back. I would't sell it back at that price anyway.
If dad has problems when it's returned, I may trade him the 5252 until I can get it resolved. That way, I'll have first hand knowledge of exactly what's going on with it.
The good news is we both have backup mowers, he has his old 1641 and I've got an 1872 I'm pretty fond of.
I believe this dealer is just getting sloppy with their work, sometimes, stuff just happens, but he better not have another electrical or fuel problem!!!
Curt
/ 3204 electrical problem #13
Hi Ohio Guy,
What was the final outcome with this ? Hopefully positive
Duc
Hey Duc,
Thanks for asking, they had the tractor another week. I think they MAY have been more focused this time. Dad's had the tractor about three weeks and it's working great for him.
None of the visits resulted in any paperwork exchanging hands so I can't tell you what they did to correct any of the problems.
Dad loves the tractor, I hope they got it right this time!
Curt
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
John Deere 6125R (A64126)
John Deere 6125R...
2003 CASE 70XT SKID STEER (A65053)
2003 CASE 70XT...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
Gehl RS5-19 (A62177)
