318 3PT is there room...
   / 318 3PT is there room... #1
cmkh3
Kitsap County, Washington
John Deere 322
I have a 318 with the rear double sheave pulley for the rear electric PTO unit. There is currently about .3" between the rear of the bolt which holds the pulley assembly on and the cross arm cylinder between the frame which raises and lowers the MMM and or the rear attachment.
So is there enough room to change the rear lift or hitch to a 3PT hitch or do I also need to change the pulley assembly to a gear box assembly?
   / 318 3PT is there room... #2
There was a 3 point hitch kit available for the 318 so you should be OK. Check ebay. I have seen 3 point kits for the 317 and 318 on there from time to time.
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2012 WESTERN STAR  4900 SB INOPERABLE (A58214)
2012 WESTERN STAR...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
