3130 alternator output
/ 3130 alternator output #1
johnk
Elite Member
western NY
Kubota GST Grand L3130 w/ 723 loader, Ags
I was wondering what the output is of the stock alternator on a new 3130? I was thinking of adding some worklights and hope it has enough juice to run them. Thanks...
/ 3130 alternator output #2
It should. If you look, there should be stubs for work lights already in the wire harness.
jb
/ 3130 alternator output #3
jb
I believe they are under the seat (factory). The color green comes to mind on the wiring for some reason??? I wired mine direct with in-line fuse but some have done the relay installation tied to the ignition. Several ways to skin it. If you have kids you want it on relay or you better be good at keeping them away when it's parked. Under the seat I just don't recall if that's on relay or not. There were several good threads of members who did it right. Mine is fuse protected but it isn't on relay (kid or idiot proof). The alternator output?? I'd have to check as I don't recall. 30 amps perhaps. Plenty for two auxillary lights and probably double that (wattage depending).
Thanks for the replies I'll see if I can find where to hook then into... I thought there would be enough output for a few lights but just wanted to be sure..
/ 3130 alternator output #5
I don't want to take your thread, but along the same lines. I have a 3130 that I thought of installing a inverter for portable power. Any thoughts?
/ 3130 alternator output #6
According to the Kubota product literature, the stock alternator has a 40 amp charging output. That is plenty enough to run 8 55w bulbs simultaneously.
Thanks Mad,
During my search it came up nil. Doesn't have the output in the owners manual either.....
/ 3130 alternator output #8
Bill, a inverter will use more electricity than it will put out
And your ideal volts out should be 13.8, running
Jim
Don't know how I missed that in the specs. Sign of old age I guess.. Thanks. Had to read that three times to find it.
2001 CHAPARRAL B/STOCK TRAILER (A64280)
2001 CHAPARRAL...
2023 CATERPILLAR 299D3 SKID STEER (A64279)
2023 CATERPILLAR...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
2015 Case TR320 (A64126)
2015 Case TR320...
213141 (A64276)
213141 (A64276)
