30w oil
   / 30w oil #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
I just bought a Hinomoto C174. I ordered an operator's manual for an Allis Chalmers 5015. Everything is identical except the PTO. The manual says do not use multi viscosity oil in this engine but it doesn't say why. It says to use straight 30w. I use Rotella 15w40 in my other tractors. What will it hurt to use the same in this one?
Eugene
   / 30w oil #2
Not that this specifically answers your question.. but you can draw a few conclusions from it.
My op manual for my vintage 50's gas ford tractors say to use either 30w or 40w oil depending on temperature, and 90wt oil in the tranny/hyds.
However, my NH dealer now reccomends their 15w-40 diesel rated oil in most applications, and 134d utf type oil in the trans and hyds/diffies.. etc...
Sounds like they are just updating everything across the baord to their 'new' spec.. etc.
IMHO.. If the engine called for 30w oil, and still had good pressure when hot at idle.. I'd try the 15/40 and see what it did with hot idle pressures. if still ok.. go for it.. otherwise.. revert to 30w oil.
Soundguy
1997 Equipment Trailer, Dual Tandem Axles (A52384)
1997 Equipment...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2009 Isuzu (A50123)
2009 Isuzu (A50123)
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
