3039h loader problem
   / 3039h loader problem #1
clan de boye
clandeboye mb
ls 3039h
Hi, the fel on my 3039h won't curl up. The loader lifts up and goes down, but the bucket hangs loose. If you curl it down it will exert pressure and bang at the limit stop which suggest to me that the down curl is working but absolutely nothing on the upcurl. Any idea what sort of issue I am looking at? thanks for any help
   / 3039h loader problem #2
Did one of the cables connected to the joy stick come loose or out of adjustment? Just a guess.
   / 3039h loader problem #3
May be a loose Q.D. Check the quick disconnects to make sure that they are fully seated ---- actually only one would not be fully seated if you know which one that is.
   / 3039h loader problem #4
I had a similar problem when my 3033 was new. It turned out one of the screws order the rubber boot on the joystick had worked loose. Tightened it up, and no further troubles.
   / 3039h loader problem #5
I had the same problem. I found that the pioneer fitting was broken and causing no flow.
   / 3039h loader problem #6
I had that problem, and one of the connectors had been knocked loose by a branch. It caused me a bit of panic, but was able to find it pretty quickly. Good luck.
2016 BOBCAT MT55 STAND ON SKID STEER (A51242)
2016 BOBCAT MT55...
International 3788 2+2 (A52128)
International 3788...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
