3038e keeps dying
   / 3038e keeps dying #1
jasonlebleu
Bossier City, Louisiana
2012 JD 3038e
Hello all,
Enthusiastic newbie with a 2012 3038e that is absolutely amazing. I'm using it to clear a future homestead and its perfect for removing saplings and grading the washboard effect out from under reforested pines. I have a fantastic dealer that sold it to me, too. Just one annoyance that neither of us have been able to crack the code on though- After a little use, it will just die and I have to set everything back out of engagement and then crank it twice. The first time it will just crank or crank and fire momentarily and die again. The second time it will fire off and I'm back at it for just enough time for me to forget about it and then it will happen again. It was suggested that it was the seat cutout, but I've ruled that out because it will also happen if I leave it running disengaged to jump off and do something else for a moment or two. The auto primer circuit is clicking away nicely when this is happening, so It just seems like a fuel flow issue, but before I start getting into things myself because that's what I do in these situations, I wanted to ask the voices of experience out there.
Details that may matter:
bought with 186 hrs
now at 220 hrs
There was mention by the dealer of water intrusion in the tank that was apparently dealt with before the sale
I've drained the white plastic fuel bowl/access port on the right lower side of the engine multiple times
As I type it makes me want to drain the tank and confirm for myself that there's no more water, but that aside, any other thoughts?
Thanks, Jason
   / 3038e keeps dying #2
My first thought is a foreign object in the tank. Perhaps a dead insect that momentarily closed off the tank outlet but then jiggles off to allow fuel flow.
   / 3038e keeps dying
Thanks! That makes sense. I'll check that first thing, as well as a suggestion to see if the fuel cap vent is plugged, also causing a flow change due to vacuum. I'll report back on those.
   / 3038e keeps dying #4
   / 3038e keeps dying
Thanks folks. My money is now on some sort of debris because its just like those folks said- could be a few minutes, could be 3 hours. Also, if I wait a while, it may start better- or not and it may not do it again for a long while- or not. More to follow...
   / 3038e keeps dying
Well, it's not the fuel cap and I haven't been able to spot anything in the tank. That said, I can't see in there well at all, so I'm running the fuel down and plan to pull the tank this weekend.
   / 3038e keeps dying #8
Jason
You might want to rig a light in the power side wire going to the fuel shutoff. That would indicate power interuption which would cause a problem like yours.
If the light goes off while the switch is on you have a problem.
   / 3038e keeps dying
I ended up with it back at the dealer for an unrelated issue and they dug into this problem, too. Haven't gotten it back yet, but they said that the port at the bottom of the tank was all but blocked with debris, so I'm buying that for a dollar until I get to ops check it.
   / 3038e keeps dying #10
Please report back the final resolution.
2016 Hyundai Equus Sedan (A48082)
2016 Hyundai Equus...
Hyd Drive (A49251)
Hyd Drive (A49251)
PUMP JACK (A48992)
PUMP JACK (A48992)
Iron Craft FMH-220 Flail Mower (A49251)
Iron Craft FMH-220...
2012 NORMAN POWER SYSTEMS 100KW GENERATOR (A48992)
2012 NORMAN POWER...
2016 KENWORTH T660 (A48992)
2016 KENWORTH T660...
