Oil & Fuel 3032e Technical Manual Correct Fuel Filter Info
   / 3032e Technical Manual Correct Fuel Filter Info #1
jagster936
Fayetteville, TX
John Deere 3032e
I am frustrated with this technical manual. I have a 610000+ serial 3032e, and the TM127919 manual. The fuel filter info listed in the tech manual is WRONG. It references the old style Tiere 3 (pre 610000 serials) engine setup, with screen filter and secondary filter. The newer ones have a primary paper filter (inside water seperator) and a final fuel filter. But this is supposedly the right manual. Anyone know what's going on? I now cannot rely on this technical manual. They also gave me the wrong user manual with wrong info regarding this.
   / 3032e Technical Manual Correct Fuel Filter Info #2
:welcome: to TBN
Manuals are very difficult to keep perfectly up-to-date.. but very frustrating when found to be out of date.
Don't be too frustrated.. still takes some common sense on our part to interpret and verify what is there and not there.
Wish you well.. but ask here on TBN as we have some real expert members that likely can help you out. Very fortunate to have TBN
   / 3032e Technical Manual Correct Fuel Filter Info #3
:welcome: to TBN
In this environment of computers it should be a no brainer to keep manuals up to date - especially part numbers.
I don't mind using brain and common sense to decipher manuals, but I'm not going to know if a valve clearance is WRONG or something that will damage the engine later on. Or any other data that I wouldn't know unless I was engineer designing the engine.
Thank you for the replies! I do all my own mechanic work, down to the nitty gritty
As far as verifying, the correct into was not there in the manual, I had to go to dealer and get part numbers. It has a totally different setup on the primary fuel filter / water separator
   / 3032e Technical Manual Correct Fuel Filter Info #6
Had same issue with my 3038e, finally took old filter to dealer.
Seems elementary to expect right info in a 150+ dollar manual. The user manual is one thing, but I payed a lot for the technical one!
Haha wow. Well the online USER manual has the correct info. My paper one did not, ridiculous.
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
2015 John Deere 35G Mini Excavator (A49461)
2015 John Deere...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
