3025e, periodic stalling.
   / 3025e, periodic stalling. #1
JD4ever!
2017 3025E
Hi friends, hoping someone can point me in the right direction before I throw hands up and cart this 2017 machine over to the shop. For the last few months, it has consistently began stalling after 1-2hrs of hard runtime. Pattern is that power feels increasingly sluggish, and at some point it stalls. I'm always able to start it up once or twice more, but each time, it stalls again as soon as I add throttle. And at that point, I'm not able to get it to turn over... usually until I come back the following day. Sometimes the dash flashes a "HOLD COIL FAULT" error, and I've seen bad fuel shutoff solenoids described as creating these symptoms, but I'm having trouble locating where the solenoids are on this engine or even what the replacement part #'s are. The battery is 4 years old, but passed a load test. Als can't find evidence of bad grounds. Any other obvious things I can check?
   / 3025e, periodic stalling. #2
Welcome to TBN
I need to ask, do you have the service tech manual ?
I do not.. been trying to avoid expenses 😓
   / 3025e, periodic stalling. #4
Well one time at the dealers shop will pay for the service tech manual and you will have more info to work with on your machine yourself. just sayin...but hoping to help.
Turned out to be the inline fuel screen fitting between the tank and the fuel-water separator. Completely gunked up. Pulled the tank and cleaned everything out. I guess enough fuel was getting through to run for a while, but the engine would eventually starve for fuel.
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2021 Jeep Wrangler 4x4 SUV (A51694)
2021 Jeep Wrangler...
A1 MIST SPRAYERS RESOURCES TITAN X LOT IDENTIFIER 80 (A53084)
A1 MIST SPRAYERS...
300 GALLON PORTABLE FUEL TANK (A51247)
300 GALLON...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
