3-Point Hitch 3015HST 3pt. Will only pick up half way.
   / 3015HST 3pt. Will only pick up half way. #1
super55ollie
Blanchester Ohio
My three point arms will only pick up half way. The operating lever has gotten hard to move. I have changed fluid and filters with no change. I had picked up a heavy load with my carryall a few days ago(1500lbs of feed). Next time I went to use it was when the problems started. noticed in the manual there is an adjustment but can't find it on the tractor. I must be looking in the wrong area. I really don't know what I'm looking for.
This tractor was one of the last 3015hst's.
   / 3015HST 3pt. Will only pick up half way. #2
Check the jamb nuts on the linkage connected to the lever. It may be similar to my 2615. Look in there with a flashlight in the area roughly under the operator's platform. Mine were out of adjustment, and the lever was becoming almost impossible to move. I simply backed them off a turn, and re-tightened. Problem was solved.
   / 3015HST 3pt. Will only pick up half way. #3
It sounds like your friction lock screw knob backed off and fell down and jammed the lever. Look with a bright light down the slot on both sides of the lever.
hugs, Brandi
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
International 133 6 Row Cultivator (A50514)
International 133...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
