300dtc clutch is stuck
   / 300dtc clutch is stuck #1
Timberrattler68
Farmtrac 300dtc
FARMTRAC 300DTC clutch is stuck engaged. Any tips before I resort to a new clutch. If not any videos on splitting a 300.
   / 300dtc clutch is stuck #2
Get her going push in the clutch and jam on the brakes a few times
   / 300dtc clutch is stuck #3
This is not an uncommon problem. That's why many manuals recommend locking the clutch in a depressed position when parking the tractor for storage. Clint's suggestion should work if not totally frozen. Trying in a higher gear may work better than in a lower gear.
   / 300dtc clutch is stuck #4
I've heard starting engine & operating engine for sufficient time to attain operating temp with tractor clutch pedal depressed could possibly free clutch. If clutch housing has inspection cover I'll suggest to spray clutch/pressure plate with brake cleaner. Ditto on disengaging clutch if tractor is to be parked for any length of time.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
