300cx loader
/ 300cx loader #1
mired
Timmins Ontario
2008 John Deere 3520 w/cab
Looking to replace all hydraulic cylinders on my 300cx loader (cylinders all leaking)with after markets anyone know the correct size of loader cylinders has my machine is at cottage buried in a snowy garage, thanks
/ 300cx loader #2
Would it be cheaper to purchase a repair kit to fix.
or have a hydraulic shop to do it.
ken
/ 300cx loader
Had two rebuilt at a hydraulic shop ended up dealer would have sold me two original new for same cost as rebuilt now just want to buy after markets good enough for my use and by looking at tubes i would say i need more then just a simple repair kit . All Im looking for is exact dimensions if anybody would have that info.Thanks
(I believe i entered in wrong section should be in hydraulic section sorry but if a moderator can move much appreciated)
/ 300cx loader #4
Assume you are referring to the boom cylinder.
The part number for the whole cylinder is AH210819, new JD part is about $600, seal kit AH176274 is $31.
Might be able to xref the part number online. If you will tell me exactly what you are looking for I can measure mine this weekend.
/ 300cx loader
Im looking for actuel measurements has i am buying aftermarket cylinders Tks for reply
/ 300cx loader #6
If your original cylinders are still good, but just leaking, a seal kit is not that expensive. It isnt a very difficult job to replace them either. The original deere cylinders are probably specifically made to the application. Im not saying aftermarket wont work, but why spend so much more for an easy cheap fix to leaking cylinders? Also, from experience, the seals on the piston often are not bad, its always the outer seal and rod wiper that go bad. Good luck to your repair!
/ 300cx loader #7
THIS IS THE BOOM CYLINDER SPECS FOR CYLINDER AH210819. THEY CALL THIS THE BOOM CYLINDER AND THIS IS FOR THE 300CX LOADER
Hydraulic Cylinder - HYDRAULIC CYLINDER, 50 X 32-491, 67
English
Specification
Bore Diameter 1.969 IN
Rod Diameter 1.260 IN
Stroke 19.331 IN
Closed Length 26.457 IN
Cap End Type Code 01
Cap End Size 1 1.004 IN
Cap End Size 2 2.250 IN
Cap End Size 3 0.00 IN
Rod End Type Code 01
Rod End Size 1 1.004 IN
Rod End Size 2 2.677 IN
Rod End Size 3 0.00 IN
/ 300cx loader #8
THIS IS THE BUCKET TILT CYLINDER PART NUMBER AH210821 FOR LOADER 300CX.
Hydraulic Cylinder - HYDRAULIC CYLINDER, 50 X 32-422, 59
Weight:
19.40 LBS 8.80 Kg
Specifications/Illustration
English
Specification
Stroke 16.614 IN
Closed Length 23.228 IN
I HOPE THIS HELPS YOU OUT.
/ 300cx loader
tks now i can order replacement aftermarkets
/ 300cx loader #10
What type of leaking do you have going on?
Are they leaking externally?
Or do you mean they are leaking down and the bucket wont stay up long?
IF the later, and there are no external leaks anywhere, new cylinders aint gonna solve your problem.
/ 300cx loader #11
Any more info on just what kind of leak you are experiencing?
/ 300cx loader
We had a few people use the tractor and they actually scratched the cylinders pretty bad and two are leaking not sure how it happened but new cylinders are needed i was able to get aftermarkets for half price gonna give them a try tks all for replys
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Pallet Forks (A64127)
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
2022 Deere 317G (A64126)
2022 Deere 317G...
