300cx loader torque values
   / 300cx loader torque values #1
tuolumne
Danby Vermont (soon)
My 300cx manual indicates that mounting bolts should be checked after the first 10 hours. The manual indicates a value of 229 ft-lbs for these M16 bolts. I don't have any 3/4" sockets that small, and my 3/8" metric set could not stand that sort of torque even if I could deliver it with an extension on the breaker bar. A typical 1/2" torque wrench is rated up to about 150 ft-lb, even if I bought a 1/2" drive metric set it would not be sufficient. What do you folks do? They look tight. The 3/8" drive set is craftsman, maybe I should give it a whirl!
Edit - Please forgive my ignorance in this matter...the tractor is 3 hours away so I can't look...does M16 refer to a 16mm shank diameter? If so, what size head is that. Maybe my 3/4" drive set will have this covered.
   / 300cx loader torque values #2
tuolumne, the main loader bolts are 24MM, although a 15/16 inch socket fits them also (I also got a 3/4" drive 15/16" socket at Sears) I have a Craftsman 1/2" torque wrench with a 250 lb-ft. capacity with which I have torqued the bolts using a 1/2" drive socket. I have loosened them with a 1/2" breaker bar and 3 ft. cheater pipe and then used the torque wrench to tighten. Not easy, but it can be done. If you are checking the loader mounting bolts on the right side, then it is a big help (gain clearance) to remove the two bolts holding the hydraulic connector bracket and let it sag a 1/2" or so.
Dave
Thanks! Things are a bit trickier when the tractor is far away. I'm all set with 24 mm.
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2022 Chevrolet Tahoe SUV (A55758)
2022 Chevrolet...
Hydraulic Hose Crimper (A50775)
Hydraulic Hose...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
Decorative Metal 5-Point Star (A55758)
Decorative Metal...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
