300CX FEL spec
   / 300CX FEL spec #1
KennedyDiesel
Veteran Member
Central WI
Does anybody have one that can measure a few thngs for me:
1) Inside diameter of the large round tube connecting the arms.
2) Depth of the std bucket I believe they measure like an L from tip to farthest back point of moldboard.
3) Height of the std bucket (floor to top)
There is a nice spec chart for the skid loader buckets including struck and heaped volumes, but nothing for the CUT buckets.
   / 300CX FEL spec #2
here are the volume and weight specs, but i don't have measurements:
Bucket Type
Width
Struck Capacity
Weight
Materials Bucket
1350 mm (53-in.)
0.17 cu. m (6.0 cu. ft.)
69.5 kg (153 lb.)
Materials Bucket
1550 mm (61-in.)
0.25 cu. m (9.0 cu. ft.)
86.1 kg (190 lb.)
Materials Bucket
1850 mm (73-in.)
0.30 cu. m (10.7 cu. ft.)
101.2 kg (223 lb.)
Heavy-Duty Bucket
1550 mm (61-in.)
111.5 kg (246 lb.)
Heavy-Duty Bucket
1850 mm (73-in.)
128.4 k. (283 lb.)
High-Volume Bucket
1850 mm (73-in.)
0.43 cu. m (15.0 cu. ft.)
158 kg (348 lb.)
High-Volume Bucket
2150 mm (85-in.)
0.5 cu. m (17.4 cu. ft.)
179 kg (394 lb.)
4-in-1 Bucket
1524 mm (60-in.)
0.24 cu. m (8.9 cu. ft.)
256 kg (563 lb.)
4-in-1 Bucket
1830 mm (72-in.)
290 kg (638 lb.)
Grapple Bucket
1830 mm (72-in.)
0.22 cu. m (7.8 cu. ft.)
258 kg (568 lb.)
maybe this will help a little bit..
/forums/images/graemlins/cool.gif
   / 300CX FEL spec
That's a great start!
The 72" Utility bucket holds 16.6
The 72" slurry bucket holds 14.4 struck
The 72" foundry holds 12.3 struck
66" foundry holds 11.2
I'm leaning towards the 72" slurry for general purpose,and the 66" foundry for digging. All depends on the depth/ht measurements.
I also must assume that they strike the load flat with the CUT bucket rather than folow the side plate contour.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
Airco Tig Welder (A51691)
Airco Tig Welder...
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
